l008com
- Jun 14, 2007
- 755
Story time: To my knowledge, I was having no thermal problems before yesterday.
So I went for my last ride of the year yesterday since it was about 30° above normal outside. I went up a small river which was just full of leaves.
So after an hour or so, the engine starts smoking. It's a 2 cycle so that happens sometimes. But I noticed theres NO water coming out so I quickly shut it off. I lift the motor out expecting to find a huge glob of leaves and seaweed, but there was nothing. Very odd.
After a while I start it back up, still no water. But it's going to take me all night to paddle back so I put it in gear and idle with my fingers crossed. And suddenly the water is back! Flowing what looks like full speed.
At this point, I'm thinking everything is good. Engine seems to be running fine, cooling water seems to be flowing normal, everything is good. So I put it in gear and head back towards the ramp, maybe a mile or so away.
Well before long, the overheating alarm goes off. I take off the cowling and touch it and it sure is hot. So long story short here, I get into this cycle of driving for a few minutes at idle, shutting it off, splashing the motor with an oar for 5 minutes, starting it up again and driving for another few minutes.
Progress is slow but I'm getting there, until I round one of the corners and hit a very stiff headwind. No way I can make progress through that. I'm kind of running out of options. So I figure I'll splash it cool again, then just gun it and hope for the best.
To my surprise, no overheat alarm. I walk back and put my hand on the engine and its COLD. This is running just planed out so maybe 15 mph. Luckily it's November so all the boats are out of the yacht club so I just cruise on by and go all the way to the ramp. The whole area is a no-wake zone but I think my situation counts as an emergency.
At this point, I'm thinking I must have sucked up some gunk that clogged something in the motor. Even though that doesn't explain the water coming out normally. But maybe theres multiple parallel water paths or something. And going fast must have blasted out the clog?
But as soon as I got to the dock and unplugged the gas tank to let the motor run out of gas, it started getting super hot again. It was a battle to see which would happen first, the overheat alarm or running out of gas. I was splashing it with water while it idled waiting for it to run out and finally it did, probably seconds before it was going to start beeping!
So what the hell is going on here? Any ideas? The symptoms of the problem don't make sense to me. If my dad taught me anything, it's always make sure the motor is pissing water. And I've had many boat mechanics tell me that as long as water is coming out, the impeller is good to go. None of this adds up but I'm at a loss.
The boat is an old 80s thundercraft.
The motor is a 1989 Mercury 90 HP 3-cylinder 2-cycle Outboard
