On mine the drive unbolted as a complete unit pretty easily from the back of the transom and when removed it had a universal and splined shaft that slid right out with it from (presumably) the flywheel that's inside that bell cover on the back. The engine just lifted right out after taking the 2 nuts and 2 mounting bolts out. Not bad at all!and that's still something I need to figure out, how the engine separates from the drive.
I'm thinking I just un-bolt and slide the engine forward?
Or did you need to slide the drive from the transom/back?
Started messing with console build, starting with the old Mercruiser 3 button switch. Found a stainless light up button that is a great match, 2 more on the way...
View attachment 390444View attachment 390441View attachment 390446View attachment 390445View attachment 390443
View attachment 390448View attachment 390447View attachment 390442
Thanks! I was trying to come up with something to keep the classic Mercruiser style. And I totally agree 100%. I wire things like they will be part of a submarine when I can. I do like the shrink tube stuff but lately for small connections I have been using a kit of terminals that have transparent shrink plastic on them and this heat activated glue stuff inside. Really like these. Once crimped you heat it and it shrinks just like the shrink tube but you can also see melted clear glue stuff squeezing out a little and displacing the air space that was inside. I'll be posting some pictures as this stuff gets connected and you'll see em. I like how they seem to have zero airspace inside. Have had good luck with them so far. I'm definitely going to have to get some shrink tubes for when I do the big battery cables though so I'll check out that kit. Ever use liquid electrical tape with any success? My last set of battery cables I did I tried something new and doped them up with that stuff after crimping the cable to the ring terminals, then slid the shrink tube over it and heated it. Made a bit of a mess squeezing out the excess but it worked! This did basically the same thing as the connectors I was talking about but on a much larger scale.Very nice solution, classy!
Amazon sells marine grade shrink tube in various sizes and in a little handy case.
I find them to be very handy.
One example of a quick search,
For some of the larger sizes that I used for heat shielding for other projects I have full rolls of it.
but those little ones are pretty handy.
Then I just buy the connectors without the plastic connector end so I can crimp, solder, and then use that stuff to seal it up nicely.
Amazon also sells that stuff in handy little boxes with adjustable spacers.
I just try and wire and build this stuff like it's going to get wet, and it's going to get beat on by the boat rising and falling.
Thanks!Nice!![]()
Yeah, I'm guessing maybe 9000 rpm?... lol So might be self hover capable, didn't flight test. But now I have a starboard-only docking thruster!Man I was going to say, I have a computer fan that can self-hover!
It sure looks a lot like that fan.![]()
Thanks! I've always really liked cedar. The look, smell, resistant properties. There was a bunch of cedar in the boat that previous owner installed. I've been recycling the original ceiling and wall panels for stuff like this, the bathroom, dining area ceiling. It was some of the only wood in it that survived the neglect when it went out of use.your movin along very well , love the color of the 3 way. i coulda sent you mine as i still have it. lol... and its in great shape too. never know i might just send it to you ... especially love the ceder ..... great job..... now onto the next project.... The Console. lol or the Engine...... whatever one you choose.
