I have a 1989 Johnson 150 vro.I would like to disconnect the VRO system.Will this effect the life of the fuel pump?Has anyone had a problem with pump after disconnect?
Re: Fuel pump failure after vro disconnect????????
Thanks,I will cap the inlet nipple on the VRO pump.Are the wires I need to disconnect to disable warning horn on the VRO pump or on the oil tank?? Thanks John
