alpineswampmanla
- Feb 18, 2002
- 12
I have a few questions about how this is supposed to work:<br /><br />1: When you first start your motor is it normal for the water pump to have to "prime up"? My tell tale doesnt flow until about 30-40 seconds after I crank it up.<br /><br />2: Should the water out of the tell tale be hot?<br /><br />3: In cold weather will the volume out of the tell tale change?<br /><br />4: I am not running hot, and think i have a stuck open thermostat, is there any way to check this?<br /><br />Thanks,<br />Brett
