Re: vacuum switch 225 evinrude
Josh-<br /><br />Get yourself a vacuum gauge, a 3/8" inside diameter "tee" fitting and a one foot length of 3/8" i.d. CLEAR hose. Hook the gauge up to the leg of the tee, hook one side to the primer bulb/fuel hose assembly and hook up the clear hose to the other side and then hook the clear hose to the fuel inlet on your motor. Go back the boat in at the local ramp, put it in gear and run it on the trailer (provided no-one else wants to use the ramp). See what the vac gauge reads - it must be less than 4 in.HG. at all throttle speeds. Look for a steady stream of small boubbles flowing thru the clear hose - that is bad, as it can lean out the engine and cause big-time powerhead failure. JohnnyRude V6's require 3/8' i.d. fuel supply, the fuel system from the fuel tank pick up all the way to the fuel pump must be 3/8" too. The pick up screen, anti-siphon valve, a thru hull fitting, fuel/water seperator, even the primer bulb can be the cause for a fuel restriction. You've got to make sure there is no restriction. And if vac gauge reads too hi, you've then got to find the problem. Sounds like your engine needs a 7in.Hg. switch, those switched are not normally problematic. It is possible an excessive vacuum damaged it.<br /><br />-John
