1983 Blue Fin 16’ Resto
83bluefin
I thought about it I truly did. Qt of Spar was $30. Tack in everything else and it’d be cheaper to use a runny polyester or epoxy….and that ain’t saving much.
Split the difference…1:1 Mineral Spirits and Rustoleum Oil Based. I have 3 very liberal coats on it right now. Letting that all soak in for a bit and I’ll hit it again with more.
I used full strength Deck Enamel back on another wreck of a boat my family owned and it held up for a good dozen years on the exposed floor. Boat gave up before the floor did.
At some point I’m going to have to let it fully cure so I can sand it smooth before more applications of paint.
Not too worried about a couple of voids as I have a plan. Since it’s such a small boat storage will be a premium. Settled on a Scotty 452 which I can screw/bolt into the bow support.
Saw a review of one and the pedestal comes off. If it doesn’t…well, I have a dremel. :)
Going to get a USB charger port for next to it as the caddy allows for a charging cord through the bottom of the cell phone slot. Kinda snazzy.
This is the one time where I wish I had sprung for the Creality K2 Plus so I could 3D print in ABS. That’s going to be a Christmas present to the family this year…our K1 SE lacks this functionality.
83bluefin
Call it coat 4…Just trying to use up the paint mix I have. I honestly didn’t mix that much up as I had a feeling I was going to be in this exact spot…too much paint, too little to paint.
Thinking I stop here for the day, let it sit and then sand to knock down the grain.
83bluefin
Researched the sku on the mystery white plastic flooring. PVC sheet from Home Depot. 1/2” thick at nearly $100 a sheet.
Yeah that’s coming out next. Whenever it stops raining…just had a thunderstorm roll through.
83bluefin
Measured 3x, templated 2x, and cut once. It helped I had the very ends for the profile.
Don’t worry…I have the floors, casting platform, face both consoles, both inside consoles, side beauty panels, and rear bench all to build. Lots of opportunities to expand my vocabulary ;)
Anyone got a good online source for sheet aluminum? I’m finding 4x8 sheets at Ryerson (I have a warehouse local to me) but it’s upwards of $500.
redneck joe
when i was searching for aluminum i was disappointed. Where are you and do you have a loading dock anywhere you could use or at lease a big parking lot
redneck joe
Man you should have a few locals to order in. Im in small town tb and i have two companies
83bluefin
Yeah Ryerson is the biggy.
Onlinemetals looks promising too. Smaller sheets would be ok but the longer angles may be an issue. May have to resort to Home Depot for those.
83bluefin
Tried out a couple different pedestal heights at Sportsman’s Warehouse. Settled on 13” fixed height. Also tested seats. High backs are good for the cockpit and mid are good for the rear bench that will pull out and convert the bow and stern to casting seats….much like modern fish & ski boats do.
Bow piece is hopefully dry, didn’t check this morning. If not it should be dry by end of day - supposed to be up near 90F.
Picked up a replacement winch rope - nylon. Needed the smaller hook as the one on the strap, which dates back to at least 2000, is just too big to release between the roller supports. Can’t get a bow tie down in there as it sits so something had to give.
83bluefin
Yeah. They’re being replaced with flip-up cleats. Retro-mod to use the car scene lingo.
Bow eye is old school small. Still attached and functional, just small. So modern big hooks eat up realestate quickly. Need to purchase a bow safety strap to use…chain is old/rusted and the spring hook is stuck open. It’s time for the chain to be retired.
redneck joe
when i was a kid we used the bow cleats and rope, looped under the tongue. Then about half way up do some cince knots at the v, working your way back up. That tightens it all up.
I did that until a few boats ago when i thought about using a small truck strap.
83bluefin
While I could do that, my goal is to have this as easy to launch and retrieve as possible for my sons. It’s the main reason there’s a set of Boat Buckles waiting to go on the trailer.
My thought process is as my sons get older and want to go camping on their own…and drag a boat with them…that they take this one.
Got the bow support dry, did a quick sand on it, then tossed a coat of full strength Rustoleum on it. I’m not so sure I’m going to get it as smooth as I want so I may pivot as to the final finish on that piece a touch.
83bluefin
I heard it somewhere that it’s good luck to sacrifice a tool to the boat building gods. I present my 3/8 drill bit. IMG_8708.jpeg
Snapped when I was trying to enlarge the slot to take a 3/8” buttonhead bolt. It really hurt when the drill kicked my hand into the wheel hub. Probably going to have a bruise there tomorrow…
May have to trim the bolts a touch as they’re 2” long and may touch the tire if the springs compress more. Bolt probably sticks out a half inch or so from the lock nuts. Probably cut them to size when I replace the tires. Hubs really should too as they’re have bolts instead of studs which makes tire swaps interesting…
Bearings will need to be done as the rear axle seal is caked in grease, as is the axle and the inside of the rim. On plus side it does have a very dirty set of bearing buddies.
This side kicked my old butt and now it’s raining again with threat of strong thunderstorms.
Anyone got a sure fired way to get rid of sticker residue? Seems impervious to GooGone, and Acetone. Xylene?? Glass Bead/media blast and strip the whole boat?
MikeSchinlaub
Planning to cut flush against the lock nut? That's whatI would do.
Yeah, that stuff can be pretty hard to remove. We have this stuff.
It works pretty well, but I think it's expensive. Don't remember how much, but it made me think "screw that!".
83bluefin
Yeah sides are getting painted with Pettit Ez Poxy. Gotta get the adhesive off as I can feel the ridge left from it. Gonna get some Xylene, a couple respirator cartridges, and some chem resistant gloves to see where that gets me.
Plan B is to have a mobile media blaster swing by and get the upper half down to bare metal. Might be worth it in the long run. Dunno…admiral has a personal mission to remove the stickers.
83bluefin
So for those wondering…here’s my testing…
Mineral Spirits…will eventually take the adhesive off BUT it does leave a greasy film behind. Takes a long while to work. So, can work if you’re patient.
Acetone…works but definitely interacts with the white (lacquer??) paint and whatever primer underneath. Evaporates quickly but leaves a ready to prime finish. Quicker than mineral spirits but more expensive too.
99% IPA…yeah doesn’t touch a thing. Can use it to clean my 3D printer build plate so I have other uses for it.
Flex Seal adhesive remover…yes it’s a thing. Works to remove the adhesive but takes multiple applications and is expensive. If I had a small area to do this would fit the bill. Not obnoxious fumes wise either.
Xylene…health hazard, says so right on the bottle multiple times. Broke out my chem resistant gloves and 3M respirator w/organics filters…which I need new filters. Melted the adhesive in like 0 secs flat. Expensive for the bottle but works. Would have to start at transom and work forwards (or other way around) due to how quickly it melts the adhesive and the gummy residue that’s left if the rag isn’t clean. It took the spot where “Blue” was and didn’t interact with the white finish at all.
Overall winner is Xylene but needs the decal gone first. Which is why I just reached out to a company in Buffalo called Blast Off. They offer mobile media blasting. Asked for a quote from rubrail down to splashrail, only the sides, transom doesn’t need anything neither do the gunnels or interior.
I could do it but it’d take me forever and probably a drill or two.
