1969-1970 V4 Johnson 115hp outboard
vanessa_d
Hi,<br /><br />I'm doing a favour for a friend and after some informtion on a pulse pack for a 1969-1970 Johnson outboard (115hp).<br /><br />We need a diagram for the inside of the pulse pack. There's no spark coming from ours and we need a good diagram of the internals to work out what's what...<br /><br />If anyone can help with a diagram or can point me in the direction of a website that can help, I'd *really* appreciate it.<br /><br />Thanks heaps<br /><br />Vanessa<br />vanessa_dillon@hotmail.com
JB
Re: 1969-1970 V4 Johnson 115hp outboard
G'Day, Vanessa.<br /><br />I don't believe that the unit is seviceable. My manual does not provide any info on what is inside, and the unit is potted.<br /><br />Good luck.
Franki
I think schematic had a couple of posts about fixing powerpacks not that long ago, he went into some detail..<br /><br />My OMC 72 100hp powerpack was full of green resin, but schematic said that most times its bad solder joints, so if you can get the resin off the back of it.. (very hard, but possible.) you might be able to fix it..<br /><br />My might be a candatite for the car coil conversion if you can't justify spending the money on a new powerpack (I just replaced mine, it cost 350 dollars AUD, (half that for USD)<br /><br />car coil conversion is fairly straight forward to do... (and you are lucky, your model has points, mine doesn't..)<br /><br />rgds<br /><br />Frank
hardtime
Vanessa> i do not want to beat some one out of<br /> a sale, but i am working on a 150 evidrude and <br /> got one 130.00 at (marineparts.com) it cost <br /> just to go fishing!<br /><br /> good luck :eek:
G. Patton
Hardtime... No criticism intended, just thought you might want to know about the difference between the eariler and later p/packs. The powerpack on the older engines (1968/1972) are a completely different animal from the 1973 and up models. 1968/72 are "Battery Capacitance Discharge" packs and are dependent on 12v battery voltage. 1973 and up packs are "Magneto Capacitance Discharge" packs whose voltage is derived from a stator under the flywheel which delivers roughly 300 "AC" voltage.
hardtime
thank G Patton i know, Jon at marine parts went over parts book, for 5min. with motor number,<br /> my part list for 225.00, same match fix my high speed miss.
novacane
i tossed in a used gm control module little extra wiring and a used ford coil cost mr bout 5.00 bucks for both runs great :p 1972 85hp<br />evenrude with point trigger bad pulse pack oh ya changed out solid core wires to msd 8.8mm spiral<br />core very low resistance with excellant sheild <br />i used left pver peices from a make to fit set<br />cost n/c :)
