Re: old gas cans ?
Are you sure your motor doesn't have a fuel pump (i.e., takes a regular single line hose)? I had a '61 Lark that had a fuel pump, and I think the pressure tanks were discontinued after 1958. (Maybe another lister can correct me on the year.) In any case, though, OMC offered a conversion kit so the motors could be run off permanent tanks for long-range cruising. A pump from a similar horsepower OMC motor can be easily installed. Get the exhaust port cover along with the used pump and you can bolt everything right on. After you block off the "air" outlet coming from the engine and install a single line fuel inlet at the motor, you will be on your way.<br /><br /> Curt
