My 25hp johnson won't idle, is hard to start and won't plane my boat out.(14 foot jon boat)<br />The trouble started all at once.<br />I've checked the coils w/ ohmmeter, replace plugs, powerpack(not cheap for this year), rebuilt fuel pump,(although it seems to be getting fuel just fine).<br />All this started last year so I have been using another motor and working on this one from time to time. <br />I took it out one time last fall after checking the carb(which was clean as a pin) It did the same old stuff, so I cut it off and fished a little. When I went to start it again It ran like a scalded dog!! About 10 seconds later I noticed that the water pump wasn't working, so I shut it down. After It cooled A little, I tryed to start it up again, but it would just idle rough then die. But it started pumping water again. <br />After this I replaced water pump and power pack and took it out again, but I just runs along slowly with the bow in the air.<br />Could my head gasket be blown??
