1972 Johnson 125hp Powerpack Burnt up
LOSTBOATER72
I recently took out my 73 Glastron with the above outboard and the powerpack on the backside of the engine smoked a bit and in removing it I can see that is is going to need to be replaced due to a burnt hole the size of a tip of a ball-point pen. I live in Sacramento, CA and would be willing to order online if necessary but I need to find out where I can pick one up and how much it is going to set me back. I think it had been going out as the engine had starting problems prior to the little incident but the engine only has apx 180 hours on it so I think it is worth replacing. Thank you for your time!<br /><br /> LostBoater72
LOSTBOATER72
Re: 1972 Johnson 125hp Powerpack Burnt up
IT SEEMS TO ME THAT SEILER IS THE ONLY ONE THAT HAS THE 125 HP 1972 JOHNSON POWERPACK AND IT IS $235? I was hoping for a little less. Any other suggestions? Thanks!<br /><br /> Costly '72 repairs
Franki
I have a 72 100HP, which I think has the same pack,, I just put a new powerpack on mine and it cost me $370 AUD (half it for USD or $185 AUD)<br /><br />Schematic on this list has mentioned before that packs can sometimes be fixed.. maybe you should look up those threads..<br /><br />Try looking around locally.. I found an old guy that had one left over.. works great..<br /><br />you could also check marine wreckers for a 2nd hand one..<br /><br />thats how I got mine, and I didn't do that badly.. (got it cheaper then anywhere i found online.)<br /><br />regards<br /><br />frank
