Re: 1994 Johnson 200 Ocean Pro Running Temp.
Close to 150 at idle, 120/130 at above 2500 rpms. I sure some one will post book numbers. After you verify engines are running correct temps with melt stick or temp gun/probe, you can move the meter needles with a 1 ohm adjustable resistor from radio shack, insert the resistor in sensor wire close to guage.
