Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Greg,<br /><br />1. How is your fuel? Fresh?<br />2. Does the primer bulb pump up hard and stay that way?<br />3. Does choking it halfway or so make a difference?
Sure sounds like its time for a carb clean. You can try removing the drain plug at bottom front of float bowl. Sometimes drain the carb and spraying "Carb Kleen" into the hole and forcing it in with compressed air will get you by......but I'd recommend a carb disassemble and clean.....
