StriperChaser
- Sep 29, 2001
- 79
I did a search and read all the past topics about oil fouled plugs. Seems there's many things that can cause the problem, wrong plugs, low grade oil/gas, thermostat, bad coil, etc. I have just assumed I had accumulated a tank of old fuel with too much 2 cycle oil. I have to mix my oil (no VRO), have a 40 gal tank with a fuel gauge that has never worked correctly, and have never let the tank get much below half empty. I mix the oil to gas ratio (50:1) but tend to add more oil than needed rather than not enough after filling the tank. Everytime I take the boat out I just top off the tank with somewhere between 6 to 12 gallons of fuel. I haven't started trolling yet this year but need to resolve this problem before I start. I've decided to siphon the tank and start fresh with new gas, oil and plugs. Do you think that is just too simple of a fix? I wonder after reading all the other posts. Just seems that years of never emptying the 40 gal tank would lead to a bad batch of fuel sooner or later. Any suggestions?
