I want to replace prop shaft seals that let water into lwr unit. I was told to remove lower hub. I loosened 3 smaller interior screws in hub with rubber seals. Now what should I do, use gear puller to pull hub out or does inside hub unscrew somehow. Aluminum on aluminum doesn't seem like gear puller would work. Can't find book to explain procedure.
