I have a 25hp Johnson and a 25 hp Evinrude. Both are early 1970s models. The Johnson was in need of gears, so I swapped the gears from the Evinrude and put them in the Johnson. They seemed to fit fine. The problem is that when the motor is in gear (either forward or reverse) the prop will spin forward and backward. Any help would be greatly appreciated. Thanks
