Re: 18hp evinrude fuel leak
Goober.... That is a float chamber vent hole. If air can not get out, fuel can not get in. Your problem is that the float needle valve is not seating properly, allowing the carburetor to flood. The cure is to remove, clean, and repair the carb as needed.
