I am have a problem with the primer choke system on my "87" 70 HP Evinrude. If I use the primer choke system(turn the key to on for 10 secs before starting) when trying to start the motor for the 1st start of the day it will not start unless I turn it to manual and pump the ball on the fuel line. It doesn't do this every time, but it is getting more frequent. <br /><br />Is this common? Do I just go ahead and replace the primer choke solenoid or is there anything else I should look for 1st?
