I recently purchased a used 18 foot center console, with a 1989 Evinrude 120 VRO. I was told it had a new power head. The motor after running 4-5 minutes starts short loud audible @1 second intervals. The VRO was removed a few years ago. It has a brand new water pump and has a good flow of water through the pee hole. When on my initial outing it planed out good and as the audible started sounding, the rpm dropped significantly. The motor doesn't feel hot even when the audible is sounding. I reconnected a couple of wires when I bought it, leading into the head.<br />Faulty Temp. sensor?<br />Is there a rpm limiter?<br /><br />Thanks, Dan
