Re: top bearing on crankshaft is going bad
Thanks RayJay. I had wondered the same thing about the bearing being used on other motors. It's actually two rows of rollers stacked together into one cage to make a single bearing.<br />I believe they used only a single row prior to this which obviously wasn't adequate enough. It's really sleazy of Johnson to force their customers to buy the whole assembly.<br /><br />BassCat, I checked out the lube passage you mentioned. It starts at the crankcase head between the two o-rings, crosses over to the intake manifold, then goes down a groove on the intake manifold to places unknown to me. I tried fishing a soft wire through the passageway, but can't make that right angle turn on the intake manifold groove. Then I took a 10ml syringe about half full of two stroke oil, attached a plastic hose to it with a conical shapped rubber fitting that fit snugly into the lube hole, and injected the oil into the passageway. It all went through fine. <br /><br />That's not a foolproof test, but it at least tells me the lube passage goes somewhere and isn't blocked. Short of taking the carbs, intake manifold and all the attached junk off the powerhead, that's the best I can do for now. <br /><br />Dhadley or Joe Reeves? You guys around? Perhaps start a new post on this? Is it considered bad edequate to continue on with someone else's post even if on the same topic?<br /><br />Thanks for the inputs. I may have to break down and buy the whole assembly. Jeez, some household members are running short of patience with that darn motor if you get my drift. :-(
