Johnson I gnition Switch
laird42
need help,need wire color code for ignition switch<br />6 wire switch<br />M (screw)<br />S post<br />C post<br />A post<br />M post<br />B post<br />Switch was taken out with out codeing wires<br />any help??? :confused:
Lark40
Re: Johnson I gnition Switch
Need much more info. What year and HP engine? What model # ?
Frank Martin
b=red hot wire <br />m=black<br />m=black/yellow<br />c=blue/white<br />s=yellow/red<br />a=purple & any small accesories
woodshole
How can you hotwire an engine? what i mean is, I dont have an ignition switch and i want to test an engine. the wiring harness was cut so have wires there. can i just touch 2 wires together and that will start it?<br />engine is 93 90hp evinrude
Walker
Just jump the starter solenoid with a battery. It will start and run. make sure all the wire end are not touching each other or ground.
