Pitch on my boat?!
Paul L
Hi, I just purchased a 1999 16' Campion Allante 485BR. (Hasn't even been on the water yet!!, old stock) It's sweet!<br />I just purchased a 1998 Johnson (also NEW) still in box 90HP motor!<br />What pitch on the prop do I need?! I'm buying an aluminum one.<br />I'd like more input from others if this question gets answered.<br />Thanks in advance everyone!
dcfrost
Re: Pitch on my boat?!
paul,<br /><br />check with local or boat manual...pitch matched to boat size for particular motor
bmurray
once you determine what pitch, I would buy a stainless prop.
MGuckin
Pitch would be in the area of 21". What is set up to be used for? Average loaded weight?
Paul L
I called a dealer, they said to go with a 17" Prop.. he said a 19" wouldn't pick up a skier fast enough..<br /><br />I dunno, what do you guys think!? I just don't want to ruin my new motor! :) <br /><br />Please write back, thanks in advance!
MGuckin
Okay so you want to ski with it. <br />Still waiting for weight but I would think that a 17 would be great hole shot with lower max mph. If you have t&t, I would go with a 19 for a compromise. 21 would be for max. mph.<br />Got to start somewhere, need a base max rpm. Hopefully you have a tach and preferably gps for speed or someone to clock you.<br />Ultimately, motor if hung and propped correctly should turn 5800-6000 at wot.
Kiwi
I'm with MG - 17" for skiing etc and 19" for general purpose. You really can't be sure until you can gauge your top RPM - then prop your engine so that you achieve near the top end of the rev range at WOT.<br /><br />Mike
