Expert Computer Care
- Aug 26, 2002
- 4
My bro and I got a new boat(used)last year. 21'Wellcraft with a 1988 Johnson 185 hp VRO V6 engine to make a long story short, after all the alarm nightmares, new t'stats and water pumps, we found that the tube that the pump sends the water up to the engine in had a bad gromet at the top allowing the water to run back down through the housing. In an attempt to remove the powerhead to fix this we came across the frozen bolt syndrome hence 3 came out 3 broke, lower end, prop, water pump, driveshaft ect also removed, head still will not come off, soaked for days, the piece the head sits on is it expensive? Can I trash this part to get the power head off? Please help running out of money. Need sound advice please!! Or am I SOL... need to be fishing
