Re: Performance Modifications
On a 25 year old engine, I'd first make sure it is in PERFECT shape. Good compression, new water pump and thermostat(s), new plugs, new fuel pump and fuel lines, timing set, etc., etc.<br /><br />After that, make sure you are trimming it properly. Is it propped right and is the prop in good shape? What rpms are you turning at wide open? Is the hull of the boat clean? Barnacles and scum will kill performance.<br /><br />Only after you have checked/corrected any of these issues should you look at upgrades. Else, you may be throwing money away.<br /><br />Check out Boyesen Power Reeds (
www.boyesen.com). I've not used them but they sound good. That's really the only upgrade I know of.<br /><br />Good luck.<br /><br />Brian
