hot 9.9 Johnson
Mr.Bill
1982 Johnson model #j10elcns sn#e5605615 have checked old water pump installed new one very little trickle out pee hole gets hot quickley.where is the water thermostat? bad head gasket?have blown out pump riser tube ,pee hole tube, pee hole 90 BAFFELD!!!!!!
sloopy
Re: hot 9.9 Johnson
What??, Ok, did you replace ALL the things you broke
sloopy
Re: hot 9.9 Johnson
Mr.Bill
Re: hot 9.9 Johnson
Haven't broken anything! Just used compressed air to blow things out
clanton
Re: hot 9.9 Johnson
The water tube grommet may be restriction water flow, requires powerhead removal.
Mr.Bill
Re: hot 9.9 Johnson
thanks Clanton!!!!! do you think there is a thermostat????????
GF
Re: hot 9.9 Johnson
Mr Bill<br /><br />Check the riser tube for length. If you had problems seperating the lower unit you may have straighten out the tube which means it is now bottoming out on the lower unit restricting the amount of water it can pick up. This happened to my 9.9 johnson.
Mr.Bill
Re: hot 9.9 Johnson
Thanks G.F!!!!! old pump did samething youre<br />probably right.i will try that
