Re: Evinrude Fleetwin what HP? and age
Hi Mike,<br /> I've got a '51 myself. Nice running, though a bit buzzy (might just be mine). It has a neutral clutch (knob coming out top of gas tank), and the motor spins around 180 for reverse. The neutral clutch spring would wear with time to the point where they would simply have direct drive and no neutral. I have a fix for that, e-mail me if you need it. Water pump impellers are no longer available, but you can make one out of an impeller that is available. Again, get ahold of me if you need the procedure. Magneto parts are readily available at any Evinrude Dealer, NAPA, West Marine etc. I can get you part numbers if you need them.<br /> Hope you have a big canoe - 7.5hp is a fair amount of power for a narrow canoe...<br />- Scott
