First time poster......<br /><br />I have twin johnson 75s on my 22ft Mako. The starboard engine starts and idles fine. When both motors are shifted into gear, the starboard bogs down. This started out as a gradual problem. The engine would be running fine then suddenly loose power. After running for a while longer the power would regain, then drop off again. Now I get almost now power out of that engine. The RPM's drop when it is in gear only. When I fire the engine up in neutral, rpms good. I've changed the plugs, replaced the fuel lines and filters. Any other suggestions? With the mechanics in my area you have to tell them what the problem that needs to be fixed is, they are not good a troubleshooting. I'm an idiot when it comes to engine terms, so keep it basic. Thanks in advance for any help!!!
