I'm having a problem with a 1977 Johnson 25. Unit runs and has a distinct miss and coughing at idle and under load. Plugs are wet fouled after a few minutes of running. The unit requires a hell of a rich mixture to run in length of time. 4.5 to 5 turns backed out on idle screw. Exhaust so rich it burns my eyes. I've changed two secondary coils. The original plugs that my father-in-law had were Champion J4C gapped at probably 0.020", I changed to 0.040" per the clymer manual (but wrong recommended plug) and the unit idled pretty good with an occasional miss that was regular under load. I put the Clymer recommended QL77RC4 gapped at 0.040" and NGK recommended (4122?) gapped at 0.030" and unit ran like crap, missing and coughing. I took carb apart and checked for wronk float level, pulled idle screw out and looked inside...carb is extremely clean with no apparent faults. No raise in engine rpm when sprayed with WD-40. Was thinking the CD2 Power pack bad but now I'm leaning towards air leak, but both plugs are wet when removed. Any thoughts greatly appreciated.<br /><br />Thanks,<br /><br />DavidT
