Hello,<br />I have a 71, 18hp evinrude that started running very rich and fouling plugs. Local boat shop wont even look at a motor this old, so I tore into it. Turns out part of the coil covering has flaked off and ruined the seal on the shaft below the coils and points. I pulled the old seal out and everything looks fine with the bearing. Is a new seal hard to put in? What is the name of this seal? This is what is causing the problem isnt it?<br />thanks for any help
