Evinrude 6 hp water pump
binkers20
I have an Evinrude 6 hp motor. I'm not positive of the year, but think it's mid 70s vintage. I want to replace the water pump, impellar, but can't get the lower unit to drop. Through the upper/lower crack, I can see a coupling with two bolts. Is this what I losen? If it is, there doesn't seem to be enough room to fit in a wrench. Barely enough for a screw driver and then I can't break to bolts free. Appreciate any advice. Also, the serial no is J0003087, model is 6504R. Anyone tell what year this motor is.
dick
Re: Evinrude 6 hp water pump
Remove one of those bolts, that is the shift shaft coupler.
Walker
Binkers, if you still haven't got it apart give me a call. I'm in S.A. 533-9069
Scoop
Be careful on that screw. I heard it is easy to strip when re-threading. I would suggest getting a repair manual.
sloopy
there should be three bolts.. one near the front and two next to the exhust?
