Re: 90 hp Johnson runs bad
Yup, djohns is on the track. With a fishing stop after running, a little time to heatsoak, it could be either electrical or carb problem. My first instinct is to guess carbs, based on your symptoms. To eliminate as much of the electical as possible, a good cleaning of all connections is in order, including ground connections to the engine block. You said the carbs had been worked on. Are you pretty confident that a good job was done on them?
