Skirt Chaser
 - Mar 2, 2003
 - 4
I have a 2000 Johnson 175 that is having a problem with the idle after it reaches operating temperture. When I slow down and put the boat in neutral the idle will drop down from 800rpm to about 400rpm and die.The boat runs fine other than that.<br /><br />I have removed the carbs and cleaned them, Put new spark plugs and run the engine from a 6 gallon portable tank with fresh fuel to eliminate that problem and nothing seems to work.<br /><br />I did a search and found one similar problem that made reference to the clamps on the fuel line but, all of mine are stainless clamps and not the plastic ones that came with the motor.<br /><br />This one has me skunked.
