Re: 1965 65 horse hydro...no go
That type shift is in forward gear when there is NO VOLTAGE being applied to the lower unit shift coils/solenoids.<br /><br />In order for it to be shifted into neutral on a momentarily basis, 12v would have to be applied to the green wire.... but for only a fraction of a second due to the fact that the unit slams right back into forward gear again.<br /><br />It's more likely that the forward gear lobes are also worn. To prove or disprove this, disconnect the wires that lead to the lower unit (blue & green). You might want to wait until you're in the middle of a lake though as the engine will be in forward gear the instant you start it.<br /><br />Now, at full throttle, if the engine jumps out of gear, there's a mechanical problem within the lower unit gearcase. If it does not jump out of gear, then there would have to be a weird electrical problem somewhere.<br /><br />Do the wire disconnect test and let us know what you find.
