Re: 1986 70hp Johnson - Lost compression in top cylinder
2 strokes do have valves. They are called reed valves. This could be the culprit but would be farther down on the list. Do a compression check and make sure you have the correct fuel/air ratio, good spark and do a compression check. Let us know how it turns out!
