Stinger 75
- Apr 16, 2003
- 7
Hey Guys, I need a little help. My drive shaft gear sheared of and really ruined a good day of fishing. I have a 1980 75hp Johnson Stinger outboard, model J75TRLCS. I am trying to rebuild it myself and need some Advice. Can anyone help me out with a copy of the schematics for the lower unit on this motor. Also, where is the best place to get parts such as gears, bearings, seals, and a driveshaft. One more thing, how do you remove the prop shaft? I have removed the bearing retainer housing and removed the two internal lock rings. The first gear slides off the shaft but that is as far as I can get. Is there some way to release it from the trans or does it all come out together.<br /> Thanks, Kelly Pope kkzpope@netzero.net
