Jim Whitlatch
- May 5, 2003
- 3
I recently purchased my first boat and am having an idle problem. It seems to run real rich and will die at the worst possible time then is hard to start.I changed plugs but it still isn't right. My question concerns the timing advance linkage. The piece that looks like a small shock absorber. When I advance the throttle this linkage advances the timing ( I think) to full advance before the carburetor butterflies start to open. Is this normal? To me this seems like it could be my problem if the timing is fully advanced at idle speed. I'm new at outboard motors so correct me if I'm wrong. The motor runs fine at wot around 6000 rpm and anywhere from around 2000 on up.
