Have Late 70's Johnson Hydro Electro Glide 85 hp outboard. Recently tried to start it and would it would run but not for long and would not leave idle. Further investigation I found two wires leading from Box on back of engine that says 12v ground. These two wires lead to underneath the flywheel on the top of the motor and I can not see where they go. They were completely coroded and fell apart in my hands. Now motor will not start at all. Am I correct in assuming that these two wires are the low voltage part of the starting system? I am going to rent a puller to get the flywheel off in the morning so that I can attempt to fix the problem. Any advice would be appreciated. I do not know much about outboard engines as you can probably tell.
