Re: milky lower unit gear oil 73 85hp johnson
Hey Larry....is that frapachino or crapachino??<br /><br />Actually, there are four places you can get water infiltration. (just a big word for "OH Crap!".<br /><br />Prop shaft seal, shift rod O-ring, drive shaft seals and the O-ring on the bearing carrier.<br /><br />Easiest way to find it, drain the lower unit of oil, rig a bicycle pump up to the lower unit, put about 10psi of air in the lower unit and put the whole thing in water and look for the bubbles.<br /><br />But...since the old girl has some age on her, opt for a complete re-seal of the lower unit. And as long as yer in there, throw in a new water pump impeller to round out the job. If your gettin' water in there that quick, don't wait to long to get it fixed.
