Re: Can I make a "Pee-hole"? 1974 70hp Johnson
I would ask the local Johnrude mech where to put it, as they had a service bulletin on the placement of telltales in the exhaust cover awhile back. It's down low on my 1980 Johnson 75hp, but I've seen some up high, too. The placement is actually somewhat critical as it can create/prevent air pockets depending on where the oulet is... <br /><br />As long as you're using 1/8" ID tubing, I wouldn't worry about draining too much water off, as the later 70s all have the telltales and they all use basically the same cooling system. As long as the telltale is near the end of the cooling water pathway, you should be good to go... Just check with a mech, or perhaps take a peek at someone else's newer 3-cylinder Johnrude (c.1990?) and note where it is on theirs. Best way to do it would be to pull the exhaust cover off so you don't get metal shavings inside...<br />- Scott
