I have a 71 50hp johnson model#50ESL71S that starts and runs great out of the water but once you get it in the water it wont go faster then headway speed. I noticed that the plug in the bottom cylnder wasnt getting as hot as the top and the plug was staying wet with gas and the top was dry. I was told I may have a bad coil so I switched the bottom coil to the top and the problem didn't switch cylnders. Next I put new NGK plugs in now it seems that both plugs are getting hot but the top plug was darker and came out dry while the bottom one looked almost new and came out wet. I was told that if it wasn't the coil I probably have a bad switch box. Does anyone have any ideas or agree with the swith box idea. I want to make sure before I go blow more money on another part that might not fix it. I would bring it some place but it's hard to find a place that will work on a motor this old. Thanx for reading and look forward to any help.
