Starting my boat since last winter
Bernard
Hello to all:<br />I took my boat out on the river and assume that it would start right up. But before I did this, I put in fresh gas/oil mixure and I change the spark plugs because they looked like they needed to be change.(brown stuff on the end) As I launch my boat into the river this is where the problems started to occur. I don't have a battery, so I have to pull and pull nummours time and nothing happen. I had the fuel gage on rich as a nearby boater told me to try. After many times of pulling the crank cord I tired myself out. Last year I didn't have this problem.I plan on bying a battery but for now I want to know why the boat won't start. Another boater told me to pour a little gas in the carberator as first time user. I didn't know for sure where to pour the gas so I left that suggestion alone. I did have it winterize but nothing was done for the summer. Like I mention, I assume it would start. What seem to be the problem. Here's the information that I have about my boat...<br /><br />1969 Evinrude 25 hp outboard<br />the gas/oil mix ratio 50:1<br />There's a p/n wire to hook a battery to the motor. But for now I usally pull start it.<br /><br />Thank you
steelespike
Re: Starting my boat since last winter
Lets start with the easy stuff.<br />Be sure the gas connectors are hooked up right.<br /> The latch goes on the pointed pin.<br /> My brother inlaw got his on backwards once,discovered it by accident or we would still be cranking.Squeeze the primer bulb till firm.<br /> be sure the choke is closing right.Does it have a manual choke? if not you may need the battery to choke it.If it is an electric choke there may be a manual choke under the hood.<br /> The kill switch, if any, may be shorted or damaged.Find the wires and unhook them and try.
Bernard
I will try what you have suggested to me. I never did see if the gas lines was hooked up properly. They seem to snap on right, but I didn't smell any gas while I was trying to crank it up. Also the prime bulb had gotten really hard. Yes, I do have a manual choke which is located in the front of the motor. I have order a manual from iboats.com and I too agree with you on working on any motor without a manual. I will keep you posted om my success.<br /><br />Thanks<br /><br />Bernard
Bernard
I want to let you know that I got my boat started. I just needed to allow some water to get into the lower intake unit(using ear plugs) :) and spayed some solution into the spark plugs socket and the carburator and a few cranks and there she goes. Basically, I needed to get some water going through the lower intake unit so that I could get some water into the water pump. There was nothing else that I needed to do. It takes only one pull and she starts right up. Again, My 1969 Evinrude motor sound good and she is ready for the water. <br /> :) <br />Thank you for your help.<br /><br />Bernard.
zj-jeepster
I'm kinda confused as to getting the water going for cooling and actually starting the sucker. Gas in combustion chamber should help starting but the water thing I don't understand. If my motor is not getting water for cooling it should not start? Not that I want to start an engine without cooling but is there actually a sensor or something? Sorry to ask a question within a thread.
