adam171771
- Jun 9, 2003
- 26
Johnson V6 crossflow (175hp)Replaced gaskets on exhaust plate, using permatex ultra grey gasket sealer on both sides of both gaskets. Fired up motor...still getting wet in #1. Pulled power head off and split crankcase. Water contamination present from crancase side of the reeds in #1 right through to exhaust. Intake side of reeds are clean. Upper center bearing also contaminated with water. #2 clean, #3 small amount of water present..the rest are clean. Have been told that crankcase seal could be the cause so I am replacing it..but I do not see how this could be the cause since no water passages are sealed by the seal, so I am guessing that the crankcase seal isolated crankcase pressure between cylinders. My compression is 150lbs on all 6. On visual inspection I see no cracks...anybody have any ideas?
