steve_results
- Jun 23, 2003
- 3
Happy Tuesday!! Have a noted 70 hp, read lots of postings so I cleaned the tri-carbs, including the high speed jets. Checked for clogged gas lines, correct float height, clear float bowl inlet jet and no damage to the float valve. All looked good when I was done. BUT...most times the motor boggs down/hesitates, almost dies, when I give it full throttle. If I baby the throtte back and forth slowly increasing, it will eventually pick up power. I also checked the gas tanks for no vacuum. Hesitates with both gas tanks.<br />My thinking is why when the float bowl seem full and the jets clean? Spark problem? Erradic advance?
