Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i have a 1983 90hp johnson that I am re-building and have gotten some help from you guys and i have another question for you. I am just about to bring her back to life and want to know what my compression should be on the cylinders.
after your rebuild your compresion should be around 100 to 120 psi make sure you do your compression test with your throttle open, your engine wonèt start if your below 90 psi and make sure you donèt have to much oil in the cylinders it will give you an incorect reading
I wouldn't make much of whatever the readings are (so long as they are within 5% of each other) until the motor is broken in. You need to do the break in just as if it were new.
