canadajohn
- Jul 14, 2003
- 5
my 1986 evinrude 110 has trim/tilt that works up but not down. Solinoids click and check out fine. All wiring checks out from throttle switch to harness connection and from connection to relays. When throttle switch is in up position everything works fine. In down position wires heat up. TT motor has 2 wires blue and green. When connected to battery terminals TT works fine both up and (when reversed) down.<br />I think it might be a dead short but have no idea where as everything looks good. I have continuity on all wires in the harness from throttle switch to connector. Does the motor require grounding or is this done internally? Any hlep or advice would be great.
