18 evinrude 1963 fastwin
bhall
I recently acquired a 18 hp. evinrude fastwin 1963. When operating in a tank it appears to run normal however when the motor was installed on a boat and put in gear it began to skip in and out of gear when accelerating. Reverse is fine it only happens in forward about 3/4 throttle. I am looking for some insight into potential problems and solutions. Thanks.
NathanY
Re: 18 evinrude 1963 fastwin
Probably either the shifter needs adjusted, or it has a worn clutch dog.
bhall
Are the only adjustments for the shifter at the coupling within the case?
