70 hp evinrude loses power after 2k rppm
saltydog73
I have a 1984 70 hp Evinrude that, under load, idles great at all RPMs and in gear until around 2000 RPMs. It runs in gear at higher RPMs (5000) great for first 5-10 minutes and then it bogs down and will stall. Compression on all three cylinders is 120, fuel tank is clean, new hoses and fittings from tank to carbs, rebuilt carbs, new fuel pump, new spark plugs, new rings on the pistons (one piston wall was scarred up – the compression was 120 after the new rings). Second trial… same result. The carbs were taken apart and cleaned again. Second trial… same result. Any suggestions?
Joe Reeves
Re: 70 hp evinrude loses power after 2k rppm
Salty.... I understand that you are saying that the engine goes into gear okay, and that it takes full throttle with no problem, then after approximately ten (10) minutes, it stalls out. <br /><br />That would indicate either overheating or a fuel restriction. Since you say nothing about overheating, that leaves the restriction. If you're using a built in tank, the following may apply. Note that the following covers various engines.<br /><br />(Fuel Anti Siphon Valve)<br /><br />Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vaccum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.<br /> <br />NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models. <br /><br />The fact that a engine is not overheating, but the warning horn sounds off (V/6-V/8) with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. <br /><br />Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
saltydog73
I don't know for sure that the engine is not overheating. The water coming out of the pee hole does not change in volume being discharged, but I have not checked the temperature.
Joe Reeves
Salty..... YOu have a warning horn that will sound off before that engine gets hot enough to do any damage. To test it....<br /><br />Turn the key to the ON position. Find the TAN heat sensor wire that protrudes from the cylinder head and ground it to the powerhead, which completes the horn warning circuit.<br /><br />The horn should sound off. If it does not, find out why.
saltydog73
I checked the overheat alarm and it works, so I do not think that the engine is overheating. I have read other posts for similar problems and saw that people were recommending testing the power packs and ignition coil. Could this be a possible cause for my problem? I tried to spray carb cleaner down the barrels while the engine was running after the carbs were rebuilt. The RPMs would surge when the cleaner was sprayed into one of them. I cleaned the carbs again and there was no change with the problem. Also, since the carbs have been rebuilt and new rings installed, should I be concerned with timing or synchronization? Thanks
Joe Reeves
Salty.... So we can assume that it is not overheating. Have you check that anti siphon valve as I explained it?
eula30
salty<br /><br />I had the same problem with my 1986 50hp mercury, Motor runs fine for about 5 to 10 minutes after that motor will loses power, it feels like the motor is running on 3 cylinders. MY problem was on the Power Pack. Run the motor until it loses power, after the motor loses power check for spark on all 4 cylinders. <br />Hope this help!!!
saltydog73
The motor is running and I am back on the water. Thanks for your help. It turned out that there is a steel (not stainless) bolt in the carbs that had become rusted. This bolt is underneath the high power jets and was not cleaned properly. The rust would clog the carb after a few minutes of operation at high RPMs
I'm taking this as if it is an Outboard....just my 2 cents, DO NOT spray carb cleaner into the carbs. Carb cleaner does not have any oil in it, you will scar your cylinders up. If you have to do this, use WD-40 or a gas/oil mix in a spray bottle. I've seen to many people do this and loose a motor because of it.
