northcoaster56
- Jul 13, 2003
- 1
I have an Evinrude 40 HP Big Twin, not sure of the year but it's a model 40352D, serial #E01144.It starts ok but will only run on one cylinder at idle and off idle speeds. To get it to run smoothly I have to lean the mixture and run the engine speed up to clear the misfiring cylinder. Once this is done the motor will run wto and mid range speeds just fine. I can even slow down to almost idle speeds with no problem.The motor will buck and eventually die if I try to go to slower in the leaned out condition. The motor also refuses to start in the leaned out state. I've been making do by richening it up to start and clear the dock, and then leaning it out as soon as the choke opens. I reverse the procedure when making a landing. Plugs are new Champions. Replaced points and condensors a couple of years ago with no improvement.Last compression check showed low 90's for both cylinders. Any ideas?
