My water pump does not seem to be working<br />Following the service manual, I've placed it in reverse, removed the trim tab bolt, removed the bolt next to the trim tab, and removed the four bolts holding the lower gearcase to to exhaust housing, and the lower gearcase has dropped about 1"; however, can't get it to separate the rest of the way. Also, removed the starter and can't see any setscrew in the engine compartment on the shift lever.<br />Did I forget to remove something or is hard-core pry force necessary??????<br /><br />Thanks
