1999 Johnson 115, Fuel problem... HELP
jeepthing13
Boat ran great, then all of the sudden it started running out of fuel. If I keep pumping up the fuel ball it will stay running. I tried replace the pump diaphram and it did help a LITTLE, before it would only stay running for 1 minute now it will run for 2 allmost 3 minutes without pumping.I also put an in line filter and replaced the stock in line element.<br /> I usualy like to try and fix things myself but this new motor is Star Trek to me. I hope someone can help me before I give up and bring it to the shop. :confused:
trumpetbucks
Re: 1999 Johnson 115, Fuel problem... HELP
Does it do this at both idle and fast speeds?
jeepthing13
Yes it does this throughout all ranges, the more fuel I use the quicker it dies. I can idle in gear for close to 3 minutes and it will run out of fuel unless I pump up the fuel ball. Or I can start to get on plane and it uses the fuel up fast, you realy can't pump the fuel ball while I'm getting on it like that though.<br /><br /> I've tried it with the cap off the fuel tank, which should give it plenty of venting I think.<br /><br /> Thanks guys, I'll check back in the AM .
jtc1945
Do you have VRO? If your running the engine on the primer bulb, only (because the fuel pump isn't working)keep in mind that your not pumping oil. I just went through this on a 90 HP evenrude. The one year old VRO pump quit working(upon dissassembly of the pump I found that the S.S. piston that meters the oil was stuck in the housing, when stuck it won't allow the fuel diaphram movement). I bought another new VRO pump at Mastertech, $ 235.00 complete), best price I could find. My engine was overheating while running on the bulb (no oil). Now running good w/new pump. If your mechanically handy, its less than a 30 minute job. I also have a new 175 johnson, the VRO scares me, I think it's over priced crap & partial cause of the Evenrude- Johnson demise.
