Re: Water pump removal
Hi Wade,<br /><br />If it's like my 85 120 hp:<br /><br />Find a socket, swivel and magnetic insert for removing and installing the shift rod screw.<br /><br />Use a coathanger to align the screw and the holes when putting it back together.<br /><br />Make sure no one touches or turns the shift rod when the lower units off, these screw in and adjustment/specs are critical.<br /><br />Clean the mating surfaces between the lower unit and upper. I have water leaking out of there now. Maybe I should have "flat filed" surfaces looking for high spots.<br /><br />Hope this helps, and Good Luck!
